Hi folks. New to forum. I was mowing fine and let another operator ride to the dumpster 200 yds down the ally to dump clippings. He used the "cruise control" feature. When he returned he stopped the machine for a few moments. When he restarted the machine to put it away it would It would slightly try to pull itself but could not move itself. I've made sure the brake is off, the little rod at the back is pushed in. The belt does feel very loose. The cruise control dogs are separated by about 1/16" and thus will not mesh and cannot be made to mesh. I talked to a JD rep, he felt the cruise control thing would not cause my problem, and he said to see if possibly the axel/wheel key has sheared. I'm on my way over to check that out. Have any of you folks got any ideas? Thanks
