I'm new here...found the site trying to solve a fuel filter issue I have with my JD yard tractor. All help is certainly appreciated.
I have a JDSTX38 hydro. Had it serviced last week...new blades, oil change, fuel line leak fixed. They also replaced the filter with one that has a clear "bulb" and a bright yellow filter. When mowing yesterday, the engine, after running like a charm for 10-15 minutes, would all of a sudden start a chug-a-lug sound, then cut off. I turned off the fuel line, disconnected it at the fuel filter, then opened the line for gas to go in the bulb. After doing that a time or two until the bulb was real close to full, the tractor start again. It would run 10-15 minutes, then I'd have to go through the ordeal again. Any ideas?
There are also some inline filters that are not very free flowing... unless they have fuel pushed with a good fuel pump they will not keep up with fuel flow...
some have such a small filtering capacity that very little fuel flow will plug them up, if there is anything in the fuel that needs to be filtered out.
Try no filter for a bit and see if the problem goes away.. if it keeps running, look for a free flowing gravity feed filter....:smile:KennyV
The paper filters have to go in the line a certain way. There should be an arrow on the filter to show the fuel flow if not then the cap o the filter should go towards the pump
Thanks for the response. I took it to a local guy who works on mowers and he cleaned out the fuel system and things are working fine...now, if I could just get my wife to mow...
