Both defeats are relatively simple. But you didnt hear it from me. The safety features are there to protect dummies like us and they shouldnt be tampered with. But strictly for educational purposes.......
1. To defeat the reverse blade shutoff, lift the hood and pull the connector off the back of the yellow button on the dash. Not the blade engagement button, the other one that lets you mow in reverse. The manual calls it the RIO switch. Insert a jumper wire in the connector and you'll be able to mow in reverse whenever you like without messing with the button.
2. Defeating the seat switch is a little more complicated because there are 2 interconnected circuits involved. Rather than try to figure out the electrical, there is the 6-minute lazy way out. Flip the seat up and remove the 4 bolts that hold it to the frame. The seat switch is in the middle bottom of the seat. Give the switch a slight turn counter-clockwise and it will come out of the seat. Remove the dome structure from the switch assembly - it will be very obvious when you see the switch - and insert something in there to hold the plunger down. A wad of paper towel or whatever. Re-assemble and you're done.
Now you can mow in reverse and get off the machine with the motor still running and the mower blades spinning - dangerous as hell.
