Naw, but humid weather causes a lot of condensation, just loosen the nut or solenoid on the bottom of the carb, and let it drain
and sit in the sun for the day and dry out first.
Water will lay in the bottom of the carb bowl, and it will run ok until you go up an incline, turn real quick, jiggle, etc....
Just something that you should check first, it doesn't cost anything, and very well could be your trouble.
