I have been considering purchasing the jd mulch kit for my older john deere 320. It has the fd590v engine. My issue is I have several trees on the 1 acre property in a residential neighborhood. I would like to mulch the leaves rather than bag or discharge the leaves out the side of the mower deck. If I discharge them out the side of the deck I have to mow over them again and again to get them ground up. And the leaves aren't evenly disputed throughout the yard.
The dealer shares with me.
A mulch kit will make the tractor work harder.
The grass will need to be cut more often otherwise it will leave clumps.
I'm not sure about the mulch kit.
The dealer suggested installing gator blades with or without a mulch
Are their aftermarket mulch kits that will work with the jd 320?
I'd like to know what others do during leave season.
Thanks in advance
Thanks in advance
