NoTTD,
Just in case you are not fluent in Australian slang what Bert was saying is it sounds like you have a relay going out. If you touch each one you should be able to feel the vibration from the contacts opening and closing rapidly. If you can't do that for a while you might pull the negative battery cable just to be safe.
Tom
