I am partially disabled and have a farm. I can do many things but cannot walk very well up and down hills and over rough ground. If I need to fix a fence I can do it if I can get there with the tools and equipment. I have a Piece of crap John Deere 145 Riding Mower with the deck removed that I use to ride up and down about a 15 to 20 degree grade and pull a little trailer with tools and sometime 500 lbs of feed in it. I am well aware of the problems cheap John Deere riders have with their Hydrostatic trans axle. Mine when warmed up will not pull me up the hill without trailer.
I need to know a good older brand rider that I could get and use to help me around the farm. I dont want to go out and buy the same problem that I have now, so I need a good solid mower with a good reputation. I cannot afford a new mower as I put over 2grand into this John Deere that is not worth 500 dollars. I will not use this rider for cutting grass I will only use it for utility work around the farm.
some of you knowledgeable rider people out there give me your advice.
Thanks in advance for your help.
