Either of those mowers would absolutely toy with a little over an acre of grass... Dixons are very good mowers so are Hustlers. Pick the one you really want, even if it is 800 dollars more, because it will last you forever and you might as well open your garage door to the mower of your dreams.
Also consider a gently used model... unless you just have too much $$$.
