Export thread
Hustler 4400 Range Wing
#1
C
coledurango
Anyone familiar with older Hustler.. my 4400 drives straight forward and backwards fine.. runs out fine, but when turning either direction it's jerky and slow.. just bought it used last week it had been sitting 6 yrs but fired right up with a battery and diesel fuel..
#2
mhavanti
mhavanti
Cole,
Jack up the wheel motors. Run the sticks forward and backward for about ten seconds in each direction several times to see if the hydraulics may have gotten some air in them. They may smooth out.
Max
#3
C
coledurango
I found that where steer rods connect to valve there were no bushings.. Only the 1/8 inch pin in the 1/2 hole so valves not fully shifting..
#4
mhavanti
mhavanti
That would make them loose travel at the pivot point for certain.
