Husqvarna GTH26V48LS No start fuel problem
clcmbtn
So I was given this mower and it only has 49 hours on it. However it had been sitting for over 4 years. So I pulled the fuel line from the pump to the carb and cranked to see if it was getting fuel. It wasn't. So I drained the tank and put a new pump, filter and the little vacuum hose. Still had nothing, so i pulled the fuel line from the tank to the pump out and replaced it with a new one. In doing so I noticed the 2 fuel pick ups that go into the tank and connect to the reserve valve were sitting crooked. I pulled them out and the grommets were all dry rotted. I have searched as many parts places but can not find these pick ups. This isn't my only problem but figured I would start with at least getting fuel thru the pump. Anyone know where these 2 items can be found?
TIA
