The small hose on the bottom of the carb hooks to the fuel filter.
The larger hose hooks to the top of the carb then hooks to the short nipple on the primer bulb.
Then the final hose hooks to the long primer nipple and is routed to the fuel tank.
The fuel is sucked through the carb into the primer bulb and discharged back in to the fuel tank.
