I have a Huskie LT4200 (42 Inch Mower) that will not move in forward or reverse. Have checked the manual and there is no indication of any adjustments.
Is there a filter to clean or anything else that I can check myself? Anyone have any diagrams or instructions? I have lifted the mower off the ground and the drive belt was put back on and everything runs normal. I just cannot get the mower to go forward or reverse.
So much more information needed: what happened when it broke, has it been giving you any trouble prior to stop moving, manual or hydrostatic, belt or shaft drive, check the transmission oil or fluid, read your owners manual and then post all needed information as somebody my be able to help.
Good luck
chjr69:confused2:
There is a manual bypass lever on the back of the tractor down low. If it is pulled out and locked in place it will not let the transmission engage. May be a simple fix that was over looked. Worth checking out.
