There was already a problem with the mower because it was hard to pull start. But, when it started it ran fine. Last week it was even harder to pull and I couldn't start it. When I pulled, the blade was moving. So I was trying different things and found that if I pushed the blade engage lever, I could start it. Once started I tried to disengage the blade and it seemed like the blade brake was engaging and smelled like it was burning. So I taped the lever and cut the lawn. Anyone know how to fix?
