You will get better answers on this on a motorcycle forum. As to what I know you need some back pressure or you loose power. So if you just install a straight pipe you will make a lot of noise but loose power. I am going to say your best bet would be a custom exhaust system which by going to a motorcycle forum you will get better knowledge on this. You are also going to find that custom exhaust systems don't come cheap.
