Export thread
Honda GXV530 will not rev up.
#1
H
hkirby
I have a Hustler Fastrak 42" with the honda GXV530 engine. I broke the flywheel fan by backing under a deck. The mower still ran fine but after i replaced the flywheel fan it will not rev up to the proper RPM. I've pulled the flywheel to check the woodruff key, it appears to be fine. Has anyone had this problem.
