i am currently building a snowplow at my school and i was wondering how strong of springs i should use i want them stiff enough that it wont just tip over, but light enough tht if and when i hit something solid it will tip down.
#2
Mwh0428
I would say that if it's for a truck use springs from a truck snow plow etc.
How big is the plow and what are you pushing it with?
#4
Grass ala Mowed
And what is the mechanical advantage of the plow with your attachment points? If the springs are low on the plow, it'll take a stiffer spring than if they are attached high. Think of the plow as a pry bar; if you grab it near the prying point, you need a lot of muscle - stiff springs, if you grab it near the other end, less muscle, softer springs.
