I think it will be easiest to find a reasonably good, USED, push mower...
& then only cut a small area for your lawn, NOT the 3 acres...
You will be better in the long run, maintaining a lawn size that you can keep up with, than trying to cut a space that you will not be able to knock out in the time (and equipment available).
:smile:KennyV
