I recently acquired the Hustler in the photos and I am having trouble identifying the model.
It currently does not run and I am hoping to get it running to use around the place. It is powered by a kohler engine but again I have no idea what model the actual engine is.
I have been able to get it to crank but even with a bit fuel down the carb I am not getting it to fire, closest I got was flames coming out of the carb.
Any way, any info or and ID so I can find some repair / workshop manuals would be great.
Not sure if you are still trying to identify your machine, but from the photos it would appear to be a Model 272A which is a 1970s era Hustler product.
