Grease Nipple Access on 44" Exmark ZT and larger. Any tricks ?
Born2Mow
  • / Grease Nipple Access on 44" Exmark ZT and larger. Any tricks ?
It is time to inject some grease into the belt tension arms on my RAE708GEM44300 zero turn. I like to do this in Spring as part of my annual maintenance. I have to get on my knees, but I can easily see and access the nipple for the BLADE belt tension arm.
However, the grease nipple for the DRIVE belt tension arm is another matter. There is one because I once greased it, but now that everything is covered in a coating of dust, things are much harder to find. I have taken off the RH drive wheel without finding it. I have removed the driver's foot plate without finding it.
What is your secret to locate and reach this elusive Zerk ?
