Hello,
I recently had an idler pulley go bad on the left drive transmission on my 928D2. Since I had remove both belts, I decided to replace both pulleys and belts. In order to change out the belts, the driveshaft from the engine to the transmissions needed to be disconnected. I followed my owners manual to the T but now have a bad vibration at idle and at high RPM's.
I rechecked everything but to no avail. Any suggestions?
Thanks,
Craig
