Export thread
Grasshopper 718 Kay I believe 1990
#1
S
Shadow913
My mower runs fine for about three quarters of an acre then the clutch kicks out if you turn the clutch back off and try to turn it on it doesn't kick in but if you shut the key off restart the engine the clutch will go in but will only last for about a minute or two then kicks back out if you let it set for about five minutes it'll run for about 10 minutes any suggestions. I've changed the seat switch PTO switch and ignition hasn't helped
#2
173abn
173abn
sounds like your clutch is going south...russ
#3
BlazNT
BlazNT
Adjust the air gap.
