bkpipe
- Jun 30, 2023
- 1
- 3
Hi all,
My first post here so apologies if this issue has been addressed in the past - I haven't found anything in a brief search so far.
I'm trying to transition a Freedom 42 deck from my old LT155 to a new to me LT160. I'm noticing the lift bracket assembly is a bit different between the two. My issue is that the lift assembly on the 160 has a couple of metal threaded pieces (they look like arches, toward the rear of the lift assembly) with a nut on them to assist in the lifting of the deck. These nuts on the arches are rubbing against the belt on the right side, and the arches are also digging into the plastic assembly on the mower deck itself. They're also limiting the amount of mower lift up I can get when I go to raise the deck, since the threads gouge down into the deck itself.
Has anyone found an effective bypass to this issue?
Happy to upload photos if that's more helpful.
Thank you in advance!
