Hello, I have a Ferris Criterion 3 wheel mower, 22hp briggs. I rebuilt the carb about a month ago and ran the mower, went out yesterday to mow and cant get it to turn over, just click. I replaced the battery(needed to anyways) removed the sylenoid and had it checked, checked good. All my connections are good, anybody have any suggestions? Thanks in advance.
Did you take off the shroud to the starter and check to see if the cog is moving, it will prob just be spinning. If it is get a wrench and LIGHTLY tap around on it and try that a few times if nothing happens take it off and take it to get rebuilt or get a new one. Cheers
