Hi everyone. I have a F932 with a 76" commercial deck and my probem is the clutch doesn't want to engage. The solenoid is working when I engage the pto and I am getting power to the clutch itself. The clutch is fairly new and has been working fine until now. It shut off while mowing and I can't get it to do anything now. Any suggestions on what to do next?? Thanks.
Cheap fix! Generally what happens is over time, the insulation melts away on the windings in the clutch and basically shorts its self out. They'll usually keep engaging until they pull about 50 amps or so. I have to replace a clutch every 400-500 hours in my F911.
