I replaced the carb diaphragm and the mower ran correctly. I did notice one new issue and it is with gas leaking from the new diaphragm. I tried my best to screw this back together diagonally. Back right, front left, back left, front right, then the side screw.
It is leaking from the back of the diaphragm/carb area and i notice a little lip of the rubber hangs out of the back. Would this be normal or should I trim it back some so that none shows?
The screws that came with this appears to strip out easy. I will need to replace them as well.
