So I have no idea what I'm doing with lawn mowers really, but I'm going to try to explain it the best I can. First thing first the lawn mower wouldn't start. I would turn the key while holding the clutch down but the circle thing on the engine would turn a little, but not start up or anything. My dad thought it was the battery, so I went to Lowes and got the same exact battery and hooked it up. After hooking up the new battery I turned the key again and it started up. At first it had some trouble staying on when I moved the throttle up, but I let it run a little and soon could turn the throttle up without it turning off. I thought it was fixed, but the next morning I went to turn the key and it did the same thing where the circle in the engine just turns a bit every now and then without really starting up. What in the world do I do?:frown:
