Oops I mis read the post. I do that sometimes..... Yes you can try an extra gasket. Your bulb may be bad or the passage from the bulb to the carb. If that gasket is not new that could be the issue also.
I just bought a 10 pack of each for your style and the primer jet for the 3.5 HP Briggs.
