Export thread
Craftsman mower brake rod spring
#1
R
raye321
I bought a used craftsman 12hp 38" lawn tractor. Second time I used it I lost the gears. The brake rod somehow pulled out of the lever and lost the spring. I would like to know the length of the spring. Any ideas? The part # is 106888x. And/or 110422x. It would take a while to get in and I need the grass cut so I thought I could go to lowe's and find one the same length or cut to size.
#2
K
KennyV
WELCOME to LMF...
If you can not locate the actual part... . You will also have to guess the pound rate of the spring & length ... :smile:KennyV
