I recently adjusted the governor and on reassemble and checking, I have lost ignition spark.
Someone suggested that it might be a kill switch issue. I have checked the three kill switches, Seat, Clutch/Brake and Blade engage. They all cut off the starter if not engaged.
I am unable to fine any other connections. There is a single wire out of the harness below the solenoid. It is about 6" long. It has an insulated female spade connector. It had no effect when I jumped it to ground but there was a spark at the battery positive post when I jumped to there.
Any suggestions.
Thanks
Dave44
#2
pugaltitude
How are you checking for spark??
If its the spark plug against the metal of the engine then you wont get an accurate test.
You need to check with a spark tester.
