What is the correct part number for a Stilhl FS56RC trimer?:ashamed:
#2
Boobala
Looking through all my stihl books , all I've got is info on a Stihl 55 .... ( several models ) I DON'T know if the carbs are interchangeable or not . Heres a carb diagram & partial parts numbers list , I don't know if these will be of any value to you or not. Maybe another member has the proper model info. My best to ya !! ........Boobala ....:smile:
The very, very, top of each page will give the models covered .
Stihl tech support(for what it is worth) informed me that Stihl uses only Zama carbs. Look closely at the carb body and you can see a model number. A new carb or a rebuild kit are readily available if you like to tinker.
