push the brushes fully inside the guides.
On some starters there is a hole in the guide that a pin goes in.
On Briggs they come with a U shaped piece of wire that pushes out when you push the armature through the bush,
#3
Dan1129
It's a K241AQS kolher 10hp. Could I use some wire some how and hold them? I've got wire
#4
reynoldston
To begin with Kohler uses many different starter brands. To name a few Denso, Delco, United Tech, Laster, etc. :confused2:
#5
reynoldston
I rebuilt a Denso a few week back. What I used was a small cotter key straighten out. I ran the cotter key through spring so the spring couldn't go flying and then installed one brush at a time till all four were installed. As I said I don't know what brand starter you have?
