Britfellow
- Apr 29, 2015
- 6
- 15
Hello, I have a Murray Select 40" riding mower to work on ... the motor spins over but fails to start. I did my usual checks ... ignition and carburation ...all ok,I did a compression test ... no compression. I took off the cylinder head and found the piston at the top of the stroke, turning the engine by hand failed to move the piston, I was able to push the piston down the cylinder by hand, turning the engine by hand brought the piston back to the top.
I strongly suspect a broken con rod .... how do I remove the engine from the mower frame ?, can I replace the con rod without splitting the crankcases ?, any further help will be MUCH appreciated .... engine number is 28T707 ...1154-EI.
Thank you.
Jim.
Thank you.
Jim.
