With the spark plug removed... There is No compression... If it is not turning with the plug removed... you have something serious wrong.
You say you checked the oil level earlier... what is it Now? Is there any fuel in the crank case?
There is either something internal OR external jamming the engine... Hope it is external ,check the belts that the engine drives... :smile:KennyV
