Hi,
I'm looking at a Bob-Cat brand zero turn lawn mower that's for sale and was wondering if you folks have any info/experience. Per a picture on the for sale ad, the main Identification plate shows TEXTRON model number "942213". I'm a bit unsure on the last character as it's hard to see in the picture. I emailed the owner and he stated it's around a year 2000 model. In a different section of the ad it's listed as a "RANSOM" as the make/manufacturer and a "BOBCAT" model name. Per the ad it has a 23 hp Kawasaki engine. Any of you folks know anything about this mower? I've been reading quite a bit about garden tractors and zero turns and I know the Kawasaki "FX" series engine is regarded as a very good engine, so I'm trying to find out if that is likely the engine in this mower.
Any help is much appreciated.
Thanks.
#2
BlazNT
Ransom/Bobcat is the same thing. Bobcat is a good mower but 16 years old is a big deal. I will research the rest of the info you gave us. Link to the site would help too.
#3
BlazNT
Parts seem to still be avalible for that mower. Even the brake pads. So you will be able to fix it.
I do agree that 16 years old is far from new, but it only has around 500 hours on it. I'm looking for a good reliable mower to reduce my lawn cutting time on my approximately 2.5 acres (with quite a few trees to mow around). Trying hard to find a spec sheet, brochure, or whatever for that model number that lists the series or model number of the Kawasaki engine that Bob-Cat used in these machines.
