I have a Super Z and yesterday while mowing the blades just stopped spinning. I replaced the blade engagement pull switch and that didn't work either. Checked the deck, its not clogged & belts are fine btw. Any one have this problem, and if so what needed to be done? (before I take it to the service center.)
Did you ever get this fixed? My hustler flipup started doing this. I think I have it fixed. I think the plug connected to the pto switch was loose. Doesn't feel like it locks on. Will take it apart later to see whats going on
Not I. I ended up bringing it to a Hustler shop and that's been 5 days ago. He is swamped so I don't know when I'll get it back or what's wrong with it... yet.
#4
Scythe
I've been watching this thread, wonder if you had the same problem as the owner in the link.
