the blades on my mtd 42 " will not completely disengage. It is a 03 , 17.5 hp 7speed
J jcihlar Forum Newbie Joined Apr 15, 2013 Threads 1 Messages 3 Jun 6, 2013 / blades always turn #1 the blades on my mtd 42 " will not completely disengage. It is a 03 , 17.5 hp 7speed
J jcihlar Forum Newbie Joined Apr 15, 2013 Threads 1 Messages 3 Jun 8, 2013 / blades always turn #2 I fixed it, put a return spring on the pulleys
reynoldston Lawn Pro Joined May 23, 2011 Threads 92 Messages 5,705 Jun 8, 2013 / blades always turn #3 You will find a blade brake on the underside of the left step.
M Major FUBAR Forum Newbie Joined May 2, 2018 Threads 1 Messages 3 May 3, 2018 / blades always turn #4 jcihlar said: I fixed it, put a return spring on the pulleys Click to expand... Do you have a pic of this spring ? I have a 2008 model and can’t get the blades to disengage
B bertsmobile1 Lawn Royalty Joined Nov 29, 2014 Threads 64 Messages 24,729 May 3, 2018 / blades always turn #5 See the answer in your own post. There are lot of different deck sizes with a lot of different PTO mechanisms
