Hello, I'm looking for some help/advise before I bite the bullet and take my Leaf vacuum to the shop and pay through the nose. I think I'm having some type of carburetor problem. When i put some spray starting fluid in and pull the cord the engine sounds like it is going to start up and as soon as the starting fluid is used up it dies as if it is not getting gas. I drained all the old fuel and fuel line took apart the carburator and cleaned it and I'm having the same issue. Gas is getting into the carburetor but for some reason it keeps dying. I'm no carburator expert and this was my first time cleaning on but the float looks like it is working and when i spray Carb cleaner through the nozzle that the fuel enters it does come through into the carb. I haven't changed the spark pulg because it starts to run so i assume the plug is ok. Does anything obvious jump out at you? Thanks!
