Just bought a 322D diesel grasshopper, but not mowing season here:thumbdown: Any way, I figured to start it after sitting . It would not start, checked the safety switches,fuses, all was good, still the starter did not crank but the fuel shut off would work. Finally I unpluged the relay and back in, and that did the trick. Could it be the relay is going bad or not making contact, the relay was all the way in and the metal taps looked ok ????
Could be....
Also could have been a bad connection at the relay socket...
Clean up the socket by removing and replacing the relay multiple times, then apply silicon Grease to the sockets... :smile:KennyV
