Having lived in So Cal (Mission Viejo) I understand your issue w/the daily solar load. I built a Pergola for shade and would recommend one over an awning, if your HOA allows. A pergola structure is much more eye appealing then an awning, easier maintenance, no moving parts to fail, with the 'right' finish it can reduce the aging/fading effects. Plus you can hang plants from the beams to add a bit of color and absorb the sun. And less likely to be damaged during the rainy season. In the 90's that was defined as one week of hard rain sometime in January February. I'm sure that has changed as the weather cycles have changed everywhere else in the world.
I left So Cal for the 4 seasons of the East Coast. Somehow I misread the travel brochure. We seem to be having 3 seasons the last couple of years. Spring lasts about 2 weeks here in Northern NJ., then right into summer.
