recently ppurchased an atco commodore, barely used but second hand, no issues for 3 months. i then topped up the fuel and a week later noticed a green algae type substance in the fuel line.
since then its been leaking fuel out of a small hole at the bottom of the carburetta as soon as the fuels turned on before its running. i stripped it down, cleaned it as best i could (found the green stuff inside it too) when i put it back together it was fine and didnt leak until i started it up again.
any thoughts on whats causing this and how to fix it?
cheers.
#2
BlazNT
Has to be your fuel. Get new fuel and clean everything again. Include cleaning the gas tank and replace the fuel lines.
