If the oil is changed regularly, can a lawn mower last forever ?
My friend in Canada has a 1992 Tecumseh 3.5HP Push Walk Behind mower that has about 10,000 hours on it (probably more), has never been rebuilt, and is still running fantastically.
I know engines were made better back then, so that has something to do with why it still runs like new, but surely if I keep up with the servicing on my 2011 Mountfield 2.6HP Self Propelled Walk Behind mower it could last as long, if not longer ?
It was used by his father for years and it covered around 10 hours every week when he lived at a property with very large lawns. It is now only used for about 1 hour every week.10,000 hours at 19 years old? HORSE SQUEEZE...that calculates to just under 1.5 hours of mowing EVERY DAY. NOBODY puts THAT kind of hours on a push mower!!!!! So tell us just how he knows it has 10,000 hours running time? In mowing 5 acres here I put a measured 85-90 HOURS for the entire season on my tractor, and the one year I kept a record I put about 65 hours total on my two push mowers. 150 hours in 7 months mowing season works out to 1.4 hours per day, but NOBODY is going to be mowing 365 days a year.
For what it is worth, I have a 1990 3.5 hp Tecumseh walk behind pusher that began burning oil at about 6 years old, despite regular service. Your mower may be a good product, but you can forget about it lasting that long. Regular service, or not. When my JD 318 was new, they told me the engine (Heavy Duty twin cylinder Onan gasoline) would give up to 1800-2000 hours before a rebuild. At 1200 it began burning oil, despite perfect service at regular intervals.
Sorry to let you down, but 10,000 hours....HORSE PATOOIE.
I never said he did mow all year round. It is probably a little less than 10,000 hours when I think about it, but not much less. There is no hourometer fitted, I just added it up using rough calculations.So, what does the hourmeter say? And just FYI, NOBODY IN CANADA MOWS YEAR AROUND. NOBODY !!!!
Ok I'm going to be blunt Their is no way in hell that he has 10,000 hours on a air cooled engine
TOTAL BS
TOTAL BS
DAM How many axles did you have under that straight truck that you could Gross 60,000 lbs.A while ago I started a thread on TBN asking:
If a tractor has one operating hour on it, about how many miles does that correspond to as compared to a road use vehicle? There were many different opinions suggested, but if I recall right, a majority of them thought one running hour on a tractor was equal to about 35-40 miles. If I use that calculation, my near-900 mile JD has about 32000 to 36000 miles of operation on it.
BTW, I used to drive medium-duty straight trucks up to 30 tons GVW for a living. Even the low end of the diesel engine range (Cummins 5.9, 3208 Cat, Navistar DT-466) etc would easily go 350,000 miles before a rebuild, with proper maintenance. A million miles of operation on a semitractor diesel is considered a low figure.
If we calculate the 3.5 mph walking speed most push mowers have, we end up with 35000 miles of walking for 10,000 hours of use. At the equator, it is close to 25,000 miles around the earth. At a 20 inch cutting width, how many acres would you mow during one trip around the earth?
Yes you guys, I am being silly here. :laughing:
Ok you was talking what the tag said not what you hauled.10 wheel straight truck, tandem rear axle, Chevy C-65, 366 gas big block, 5 speed/2 speed rear, 24 foot van body on the back. Michigan law permits 16,000 -18,000 pounds per axle and it was used mainly to deliver full pallets of copy paper. With no load the springs were stiff enough to shake the driver apart even when belted in. The GVW for commercial trucks is always higher than the legal weight limit they can carry.
Now if you got your 1,000,000 miles out of that 366 Chevriolet without a OH you were runing on luck. It wasn't much more then a HD car engine. Almost like 10,000 hrs. a a push mower.
I know all about them seeing I was a Chevriolet Truck mechanic back in them days. When I started it was the 348 truck engine 409 car engine. As I remember they didn't hold up very well in a truck. We are still runing a 454 in one of our older pickups. A real good gas hog.
Yes, one does, but the oil is the main thing.One needs to service more than just the oil to maintain any motor.
I hear you Mister Mower, good point! If a person wants to they can make anything last a long time but not without some effort, its a matter of pride with me, plus i am a tightwad and want to get my moneys worth out of everything I buy.
I can't resist another chance to sing the praises of two-stroke engines. :laughing:
I have several two-stroke Lawn-Boy mowers that have lasted more than 25 years. There's picture below of a 1977 commercial Lawn-Boy that belonged to an owner of a lawn care company. He used it for hundreds of hours a year for over 30 years and it's still in good shape. Engine's fine (but I don't know about rebuilds) and the alloy deck is scratched up but undamaged. The front wheels are not original.
If a two-cycle engine is properly lubricated -- use a good two-stroke oil to mix with the gas -- the engine stays very well lubricated at all times. A four-stroke, on the other hand, will sometimes "starve" for oil when operated on a slope.
1977 Lawn-Boy model 6255:
