Chances are, your drive disk needs adjustment. There is a bolt to adjust how hard the disk "hits" the drive plate. Reverse is the first to go when it needs adjustment. Remove the plate on the back of the frame, and the bolt should be visible. (not sure, I've only adjusted the disk on my LT.....but I know there is a stop bolt to adjust how much tension is on the rubber disk on all of them.....)
