I have a grasshopper 721d with the kubota d722 3 cylinder diesel engine. Will mow fine for about 20 minutes then starts to lose power and will eventually sputter and stall. here is a list of what i have done so far
New fuel filters and lines
tank drained, cleaned, fresh fuel
Checked pick up tube from tank
new electric fuel pump
checked compression and valve clearances
injectors were ultrasonic cleaned
had injection pump checked out, they said delivery valves were bad, thought my issue was solved, put rebuilt pump back in and have the same issue.
i need some input, what am i missing here? i unhooked the fuel shut solenoid and the problem persisted.
