I just bought a Yard Machines riding mower with an 18 hp briggs 2-cylinder (1997 or so, I believe). I swapped in a 46" deck from a parts mower, changed the blades and freed up the spindles and double pulley (it had been sitting idle for some time). By 'freeing up', I turned the blades by hand until they spun freely. I imagine that the grease had dried in place, and this got some lubrication moving in the bearings.
The deck is working, but making a grinding noise. Can the blade spindles be opened up and regreased? Or, can just the bearings be replaced? If so, how? Any sources for new bearings?
Thanks,
Tom
Thanks,
Tom
