Repairs 42 inch Ariens 936037 gear tractor mower trans Axle vibration
BGByrd
  • / 42 inch Ariens 936037 gear tractor mower trans Axle vibration
Ive noticed a vibration and noise in mower. Removed deck and still is there. Noise goes away when slightly depressing clutch. I cant find any info on checking trans axle fluid level or changing fluid. Any ideas on this, Thanks Brad
Transmisson belt has a crack or lump missing from it or crack or burn.
One of the pulleys is damaged or has a bad bearing
