Thanks for the reply, I did start adjusting both the side to side and front to back and I could get the vibration to improve on one height setting but it became worse on other settings. The new belt is not OEM which I see can be a problem reading many other posts, I will order another one. The deck belt is very old but seems to work okay, since they are on the same idler pulley could this old belt cause the issue?
Thanks...
