Hi All,
A little info on the mower.
Troy-Bilt 21" 6.75hp - walk behind mower (model: 11a-436n211)
Motor: Briggs & Stratton 126L02-0675-F2 (auto choke)
So I picked this mower up for free on CL about a year ago. The owner said it wasn't running and he didn't care to figure out why. Well, a can of carb cleaner later I had it running like brand new.
So a couple of weeks ago it started giving me fits. It would run poorly and then just stopped starting all together. This weekend I pulled the carb, took it apart, cleaned it thoroughly and put it back on. The mower fired right up, and is running very smooth. But for some reason it's running a little weaker than it usually does. The RPM's seem down and I notice the motor get's bogged down easier when I run through a trick patch of grass.
I popped the fuel life off and confirmed that fuel is flowing normally. I also checked the air cleaner, it's dirty but not so much that i think it's restricting air flow.
Any advice on what might be causing the power loss?
