my riding mower will ride fine but once I engaged the blade it will die.....however, in neutral, the engine runs fine even if the blades are engaged....I would move the gear to forward and once I let the clutch go, the engine will die....
Basically, if in forward with clutch released and blade engaged, the engine will shut off....any thoughts.....thanks
someone mentioned its the seat safety switch, but I'm not sure
