alternative browser .
May 12, 2014 #1
D
diben004
Had the recall fixed. When the blades are engaged sounds like a bearing is squealing? Anybody experience this?
May 12, 2014 #2
R
RaptorSD
Nope. Maybe there was not enough endplay left in the clutch when they added shims? That could destroy bearings. I would take it back.
May 13, 2014 #3
D
diben004
The dealer told me it is the clutch hitting the brake and said it was normal? He stuck a piece of rubber on the brake in-between the clutch. It heated up and fell of after a few passes.
May 13, 2014 #4
M
MRCo.
Sounds like your dealer is a bit...of a twunt.
May 14, 2014 #5
chemingthroughtheleather
I agree with MRCo,dealer needs to step up and make things right.
May 14, 2014 #6
D
Dothehustle
Yes I have had no issues thus far, dealer should fix it.
