1970 john deere 110 starting issues
The Maddox
hey everyone, got some issues with my first older mower. its a 1970 john deere 110 with a k181 engine. to make it easier im going to put the problems in the order they happen haha
First problem: turn the key and the engine turns and turns and turns, but will almost never start up. like it isnt getting a spark. when it does start it runs great but im terrified to turn it off, seeing as it probably wont start back up
problem 2: after trying repeatedly to start it(and failing), it decides that it doesnt want to do anything at all. and i mean nothin'. the only thing that moves is the battery gauge
problem 3: oh boy, i finally got it running this is gunna be great!!! 5 minutes in it turns itself off. seems like its bogging itself out or running out of gas. sometimes i can catch it by either A: shaking the battery or B: pressing the clutch for about 30 seconds. but half the time im not able to catch it.
this is my first mower and im already in love with it. i just want it to work properly. can anyone give some advice and help me get this antique back on the lawn?
mechanic mark
"K&T Parts House Lawn Mower Parts and Chain Saw & Trimmer Parts" locate your engine model, tune up time, use OEM parts Kawasaki, new plugs, air, fuel, & oil filters, suggested oil in manual, adjust valves engine cold. Remove blower housing at top of engine & clean everything by hand, no water or liquids.
http://www.kohlerengines.com/onlinecatalog/pdf/tp_2379.pdf engine service manual, see troubleshooting section.
https://www.google.com/search?q=wir...BJohn%2BDeere%2BWiring%2BDiagram.html;589;600
The Maddox
i was thinking it was more of and ignition system issue and starter issue. and its not a kawasaki its a kohler
